s1975
Jul 31, 2013 7:45 PM UTC
how to make shift bits (asm STVD) , example: 1<<0|1<<3|1<<4
Posted on July 31, 2013 at 21:45
example:
ld A, 1<<0|1<<3|1<<4
it isn't compiled as it is correct to make record for the STVD assembler?
    fggnrc2
    Aug 1, 2013 4:14 AM UTC
    Posted on August 01, 2013 at 06:14 Hello user assembler shift operators syntax is different from the C one. The right syntax to load A with the result of your expression is:
    LD A,#{{1 shl 0} or {1 shl 3} or {1 shl 4}}
    BR EtaPhi
    s1975
    s1975Author
    Aug 1, 2013 8:46 AM UTC
    Posted on August 01, 2013 at 10:46
    thank you, compiled
