Central SUPPORT
Senior
July 25, 2019
How to handle LDi pins of SCLT3-8BQ7 if no LEDs are used ?
We are planning to use the SCLT3-8BQ7, but do not want to connect any LEDs to LDi outputs of the chip. The datasheet does not mention how to connect these pins in this case.
Can you please tell us if we should leave these pins floating?
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
Central SUPPORT
Central SUPPORTBest answer
Senior
July 25, 2019
In case the LEDs are not used the respective pins (LDi) shall be connected to ground.
Central SUPPORT
Central SUPPORTAuthorBest answer
Senior
July 25, 2019
