AKUMA.2
How to handle interrupt on any GPIOs on STM8L152C6?
I am using user key and three more keys to do some work.
Can you please guide me how to assign for the interrupt handler function for particular interrupt on a GPIO?
e.g. I couldn't understand:
What does the numbers like 8, 9, 10, 11 ect represents in the following code?
INTERRUPT_HANDLER(EXTI0_IRQHandler, 8)
 /* In order to detect unexpected events during development,
   it is recommended to set a breakpoint on the following instruction.
 while (1);
 * @brief External IT PIN1 Interrupt routine.
 *  On User button pressed:
 *  Check if button presse a long time (4-5 sec.) if yes --> Set Autotest
 *  Else update status_machine to pass to next measuremetn.
 *  Update the LCD bar graph
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI1_IRQHandler, 9)
while(1);
 * @brief External IT PIN2 Interrupt routine.
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI2_IRQHandler, 10)
 while (1);
 * @brief External IT PIN3 Interrupt routine.
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI3_IRQHandler, 11)
 while (1);
 * @brief External IT PIN4 Interrupt routine.
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI4_IRQHandler, 12)
 while (1);
 * @brief External IT PIN5 Interrupt routine.
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI5_IRQHandler, 13)
 while (1);
 * @brief External IT PIN6 Interrupt routine.
 * @par Parameters:
 * None
 * @retval
 * None
INTERRUPT_HANDLER(EXTI6_IRQHandler, 14)
 //while (1);
 return;
Ajeet
