H_H_11
How to generate .bin file from STVD
Hi STM8 Team,
I can see STVD generates .s19 , .sm8 files. I want to generate .bin file.
I had tried it by adding the following line in Post-Build section:
chex -o $(OutputPath)$(TargetSName).bin
But this did not work. Could you please guide me on how to generate .bin in STVD?
Thanks,
Hrithik
    Artur IWANICKIBest answer
    You are right. Within chex converter description there is no binary files, only hex and s19. This last one is default output file format.
    In fact chex is a tool provided by Cosmic toolchain.
    I do not see any built in hex2bin converter within STVD neither.
    There is no indication to the input file (.sm8) which needs to be converted into .bin.
    Could you please try instead:
    chex -o $(OutputPath)$(TargetSName).bin $(OutputPath)$(TargetSName).sm8
    H_H_11
    H_H_11Author
    Hi @Artur IWANICKI​ ,
    Thanks for the response.
    I tried your suggestion and .bin file is getting created, but the content of .bin file is exactly similar to .s19.
    Does STVD support .bin format?
    Thanks.
    H_H_11
    H_H_11Author
    Will check another way to do this.
