raja1
Mar 27, 2024 10:34 AM UTC
How to enable and disable a maskable interrupt from inside an ISR in stm8A
Hello all.
I have an ISR inside which I want to disable and enable interrupts.
Reference manual says :
https://www.st.com/resource/en/reference_manual/rm0016-stm8s-series-and-stm8af-series-8bit-microcontrollers-stmicroelectronics.pdf
Disabling the interrupts
#asm
PUSH CC
POP ISR_CC(1)
SIM
#endasm
Enabling the interrupts
#asm
PUSH ISR_CC(1)
POP CC
#endasm
I want to achieve mutual exclusion. I have tried using sim and rim and it works for now.
However the above method got me confused.
What do I do for POP ISR_CC ?
Please suggest me exact ways.
I have found this inside a blog. Is it correct?
uint8_t atomic_begin(void) __naked {
__asm
; Copy CC value, put in A reg for return value, and disable all interrupts.
push cc
pop a
sim
ret
__endasm;
void atomic_end(const uint8_t istate) {
(void)istate;
__asm
; Restore CC from arg value in A reg.
push a
pop cc
__endasm;
    raja1
    raja1Best answer
    Mar 30, 2024 1:12 AM UTC
    I was using cosmic c compiler.
    I did the following modifications for cosmic C and stvd.
    #asm
    push cc
    pop a
    sim
    #endasm;
    (void)istate;
    #asm
    push a
    pop cc
    #endasm;
    //Usage is as follows
    ISR()
    uint8_t ISR_CC_ret = atomic_begin();
    //execute your ISR
    atomic_end(ISR_CC_ret);
    raja1
    raja1Author
    Mar 27, 2024 10:55 AM UTC
    	__asm
    		ld a,cc
     push cc
    		pop a
    		sim
    		ret
    	__endasm;
    	(void)istate;
    	__asm
     ld cc,a
    		push a
    		pop cc
    	__endasm;
    @raja1 wrote:
    Hello all.
    #asm
    PUSH CC
    POP ISR_CC(1)
    SIM
    #endasm
    #asm
    PUSH ISR_CC(1)
    POP CC
    #endasm
    __asm
    push cc
    pop a
    sim
    ret
    __endasm;
    (void)istate;
    __asm
    push a
    pop cc
    __endasm;
    Does this make sense?
    raja1
    raja1AuthorBest answer
    #asm
    push cc
    pop a
    sim
    #endasm;
    (void)istate;
    #asm
    push a
    pop cc
    #endasm;
    ISR()
    //execute your ISR
