xiebintj
Aug 24, 2005 12:25 AM UTC
How to do supplying the external battery power to sram in using upsd3254?
Posted on August 24, 2005 at 02:25
ms_arefnasab
May 17, 2011 10:08 AM UTC
Posted on May 17, 2011 at 12:08
hello,
you must define PC2 pin of UPSD in PsdSoft as sram standby voltage input,then connect this pin to battery backup circuits.
xiebintj
xiebintjAuthor
Now I meet with an important question in upsd3254, I want to supply external power to internal sram, not using the internal power supplying to internal sram,even if the chip power is still on.How can I do it? Any ideas are helpful,Thanks :-[
