jeffrey23
May 17, 2010 4:25 PM UTC
How to declare a string array for STM8S103F3 using COSMIC ?
Posted on May 17, 2010 at 18:25
    luca239955_stm1_st
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    in your declaration, the first ''const'' keyword tells the compiler that the pointed object (your strings) is a constant, while the second ''const'' keyword tells that the pointer itself is a constants (ie, its value will never change).
    Depending on what you are actually trying to do, the second ''const'' might be useless/wrong.
    Regards,
    Luca (Cosmic)
