May 2, 2024
How to connect SD card module with STEVAL-BCNST01V1 or bluecoin
For the current BlueCoin Starter Kit model, does it have the ability to record audio onto an SD card while also allowing you to monitor the audio being recorded through headphones or speakers in real time? If so, could you please explain the steps to use
thank you for answer.
