Ajadh.1
how to change c language from c90 to c99 in stvd
I am using STVD to debug program for stm8s105c6 MCU. Here am able to compile code properly, and using cosmic compiler.
I am getting error for Inline, and also prototype missing, semicolon missing, invalid constant expression, etc. errors are coming.
Do they are occurring due to c language standard version or anything else?
Please guide.
Thanks in advance.
    Ozone
    Principal
    February 10, 2021
    The supported standards and the compiler flags for processing a module should be specified in the toolchain manuals.
    I had never been working with the Cosmic compiler.
    The inline error is probably standard related, the others are likely not.
    Check you MCU header file for compiler-dependant #if /#ifdef sections.
    Perhaps a toolchain define is missing, and you pull the wrong toolchain-dependant definitions.
    Ajadh.1
    Ajadh.1Author
