jeffrey23
May 14, 2010 8:06 AM UTC
How to arrange the variables at EEPROM using COSMIC ?
Posted on May 14, 2010 at 10:06
    luca239955_stm1_st
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    @eeprom tEGD tsEGD;
    @eeprom tEYD tsEYD;
    Regards,
    Luca (Cosmic)
    B.Montanari
    Hi Boltnut,
    On your main.c (or any used header) declare this:
    /*    FLASH section
    volatile char FLASH_CR1     @0x505a;    /* Flash Control Register 1 */
    volatile char FLASH_CR2     @0x505b;    /* Flash Control Register 2 */
    volatile char FLASH_NCR2    @0x505c;    /* Flash Complementary Control Reg 2 */
    volatile char FLASH_FPR     @0x505d;    /* Flash Protection reg */
    volatile char FLASH_NFPR    @0x505e;    /* Flash Complementary Protection reg */
    volatile char FLASH_IAPSR   @0x505f;    /* Flash in-appl Prog. Status reg */
    volatile char FLASH_PUKR    @0x5062;    /* Flash Program memory unprotection reg */
    volatile char FLASH_DUKR    @0x5064;    /* Data EEPROM unprotection reg */
    This should solve your problem
    Regards,
    Bruno
    B.Montanari
    jeffrey23
    jeffrey23Author
    Hi Luca,
    I tried to declare the variables as you mentioned.
    But I got some error messages as attachment.
    #error clnk Debug\A101VW01.lkf:1 symbol _FLASH_CR2 not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o )
    #error clnk Debug\A101VW01.lkf:1 symbol _FLASH_NCR2 not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o )
    #error clnk Debug\A101VW01.lkf:1 symbol _FLASH_IAPSR not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o
    Regards,
    Boltnut
    jeffrey23
    jeffrey23Author
    Hi Bruno,
    As you suggested, I tried to add the FLASH section for solving the linker issue.
    Unfortunately, its behavior is wrong even linkage issue was fixed.
    Could you give me more suggestion ?
    Therefore I changed back original declartion. It can work fine.
    EXTERN tEGD tsEGD   @0x4000;
    EXTERN tEYD tsEYD   @0x4020;
                /* Unlock Data memory */
                FLASH_Unlock(FLASH_MEMTYPE_DATA);
                if (fDown)
                    if (tsEGD.bBrightness > BRIGHTNESS_MIN)
                        tsEGD.bBrightness--;
                else
                    if (tsEGD.bBrightness < BRIGHTNESS_MAX)
                        tsEGD.bBrightness++;
                /* Lock Data memory */
                FLASH_Lock(FLASH_MEMTYPE_DATA);
    jeffrey23
    jeffrey23Author
    Hi Bruno,
    Thanks for your help. It fixed my linkage issue.
