marcosarti29
Sep 16, 2005 2:20 AM UTC
How setting jump of memory map(reserved)?
Posted on September 16, 2005 at 04:20
marcosarti29
Sep 15, 2005 5:02 AM UTC
Posted on September 15, 2005 at 07:02
i use ST7Lite 19F.
The RAM is:
RAM 0x0080 TO 0x00FE,
Reserved 0x0100 TO 0x017F,
RAM 0x0180 TO 0x01FF
In file project.prm (compiler HIWARE) i have setting:
MY_ZRAM = NO_INIT 0x0080 TO 0x00FE;
The program run :)
Question:
...and other RAM (0x0180 TO 0x01FF) ? Is it lost?
How i setting project.prm for add segment 0x0180 TO 0x01FF?
Thanks.
alok2
Yr question is how to use RAM between RAM 0x0180 TO 0x01FF. right ?
See different s/w exmples available. You can also check ST7 library.
