How does eDesignSuite calculate NFC matching components ?
- 2 replies
- 1962 views
I have to tune several NFC antennas using a ST25R3911b and I would like to automate calculations of the matching circuit depending on the antenna parameters (Rs,L,Rp,SRF). Using the eDesignSuite is a bit heavy since I have several antennas and it implies to fill manually all the fields. So I would like to perform my own calculations of matching circuit.
I used the method described in the attached file to calculate NFC matching components and my result for Cs and Cp are slightly different from the eDesignSuite results.
So I would like to know how the calculations are made by the eDesignSuite.
Cordially,
Nicolas Meunier.
