DMich.3
April 11, 2023
How do I replace the memory that came with the EVAL-SC003V1 with the STM32CubeProgrammer? It firstly erased the memory on the EVAL-SC003V1 because the default is to not skip flash erase before programming.
I'm not certain that the default memory file for the EVAL-SC003V1 was provided in any of the zip files I downloaded. Is replacing the memory sectors between the STUSB005 GUI the correct way to program the EVAL-SC003V1 board? The sectors from the GUI only use a few lines of memory and the EVAL-SC003V1 does not upload them to my PCB with STUSB4761.
