shlomo2
How do I create a HEX file from ST visual debug
  • March 26, 2004
  • 3 replies
  • 1117 views
Posted on March 26, 2004 at 09:51
shlomo2
shlomo2Author
Posted on March 25, 2004 at 14:29
Sorry for the stupid qustion - never used this tool before and I'm struggking to make a HEX file of S19 file to burn IC.
I'm using the ST72324 IC
My code is writen in C under the ST7 Visual Debug.
I'm trying to burn IC with the InDart board.
Hope this info is enough.
Thanks in advance.
delser9
Posted on March 26, 2004 at 02:56
Hello Shlomo
I thrust the following link will help you a lot:
http://www.x-ways.net/winhex/index-m.html
There you can download a good HEX-Editor for trial.
Greetings
Al
sjo
What compiler are you using, cosmic or metrowerks ?
Cosmic will produce a .st7 file, from this you can run chex.exe to produce a hex or s19 file.
Metrowerks will produce a .abs file, from this you can run burner.exe to produce a hex or s19 file. Also have alook at the -B linker option.
sjo
