Willian Lenert
Dec 7, 2016 3:09 PM UTC
How do I check the code size in STVD?
Posted on December 07, 2016 at 16:09
Is it possible to check the program size in STVD? So I can choose the correct Flash size of the MCU for my application...
#stm8 #code-size #stvd #cosmic
    Seb
    Dec 10, 2016 1:32 PM UTC
    Posted on December 10, 2016 at 14:32
    The linker typically can generate a xxx.map (text) file which contains memory (flash/ram) consumption and sometime a calling tree to manually estimate the deepest stack point (assuming non recursive functions). Usually the MAP file is next to the generated S19/HEX file which contains the Flash image of the program.
    For cosmic, open the project setting and look at Linker Output options. There should be something like 'Generate Map File' as a check box.
    Willian Lenert
    Dec 12, 2016 5:26 PM UTC
    Posted on December 12, 2016 at 17:26
    Thank you for our answer Sebastien,
    I opened the .map file, but still don't know where is the code size information, the flash consumption... :\
    Willian Lenert
    Dec 12, 2016 5:49 PM UTC
    Posted on December 12, 2016 at 17:49
    Found the answer in this thread:
    https://community.st.com/0D50X00009XkaWcSAJ
