xisco
Senior
June 5, 2025
How can I find ST product documentation? (Datasheets)
Often I need documentation of different components like datasheets.
I usually use Google and end up on any datasheet website. In some cases, mainly searching old components, I found datasheets of bad quality, that seems bad photocopies.
Has ST any public website where can download it's datasheets?
TDKBest answer
June 5, 2025
Search for the part you want and restrict results to st.com.
TDKBest answer
June 5, 2025
xisco
xiscoAuthor
Senior
June 6, 2025
Very good solution!
Adding site:st.com to the search string, Google shows only ST websites.
Thanks.
Andrew Neil
The datasheet and all other supporting info & resources can always be found on the Product Page; eg,
https://www.st.com/en/microcontrollers-microprocessors/stm32f446re.html
Usually, just putting the part number into your favourite internet search engine will find that as (one of) the first hit(s); eg,
https://www.google.com/search?q=F446RET6
Another example:
https://community.st.com/t5/st25-nfc-rfid-tags-and-readers/steval-25r200sa-custom-application-development/m-p/810347/highlight/true#M12763
