icwang
Mar 20, 2006 9:33 AM UTC
how bit manipulation in cosmic compiler ?
Posted on March 20, 2006 at 10:33
icwang
icwangAuthor
Mar 20, 2006 1:25 AM UTC
Posted on March 20, 2006 at 02:25
In other c compiler , there is direct bit manipulation.
such as
PB.4 = 1;
or
INTCON.GIE = 1;
How to write in cosmic compiler ?
Thanks.
luca239955_st
_Bool mybit; // general bit variable, requires the .bit segment to be declared in the linker file
_Bool
mailto:PA0@PADR:0
; // absolute bit variable, does not require the .bit segment
mybit=0;
while(1)
PA0=0;
PA0=1; // Generate a waveform
Regards,
Luca (Cosmic)
