MAnsa.1
Hii I want to turn ON LED
i have positive and negative voltage in the range of 1000v.i connected one LED to indicate minus voltage.
led is connected to PD1 of stm8s003f3 controller
i put this condition....
#define SevenSegmentDisplays_GPIOD_ODR_ResetValue 0x7E
#define SevenSegmentDisplays_GPIOD_DDR_ResetValue 0x7E
#define SevenSegmentDisplays_GPIOD_CR1_ResetValue 0x7E
#define SevenSegmentDisplays_GPIOC_CR2_ResetValue 0x00
(ChannelVoltage >= 0)
GPIO_WriteLow(GPIOD,GPIO_PIN_1);
else
 GPIO_WriteHigh(GPIOD,GPIO_PIN_1);
    srikanth
    hi MAnsa,
    First toggle the PD1 pin and then check the hardware connection
    I hope it's helps to you
    MAnsa.1
    MAnsa.1Author
    already checked n yeah it worked..
