Cristian GyorgyBest answer
I could not open the code you posted, but take in count that a programming takes 6 ms if not writing on already erased location.
If you need shorter write times: prepare the locations in advance by erasing them and write your data in blocks (64 bytes). A block write is just as fast as a byte/word write.
