raulhernandezfernandez
Jan 12, 2021 9:09 AM UTC
Hi there, Is there any footprint and pin compatible part to substitute the STMPE811QTR part? I just saw an obsolesce notice. Kind regards, Raul
Peter BENSCH
Peter BENSCHBest answer
Jan 12, 2021 12:36 PM UTC
Like similar devices, the STMPE811 supported resistive touchscreens, which were replaced by capacitive touchscreens. Because of the recently very low global demand, it no longer makes sense to continue producing them.
Unfortunately, we don't know of any compatible device with the same specifications.
Good luck anyway!
/Peter
Peter BENSCH
Good luck anyway!
/Peter
Jan 12, 2021 1:34 PM UTC
Hi Peter,
That is very disappointing for us. Unfortunately, three of our product lines uses the STMPE811QTR, We had to support resistive touching technology due to the fact that most of our customers need to use plastic gloves.
Thanks for you answer and have a good day.
Kind regards,
Raul
Glen Larson
Mar 25, 2021 2:08 PM UTC
Us, too! Need resistive touch for a medical device.
ChrisSkelton
May 11, 2021 9:04 AM UTC
Hi guys, did anyone find an alternative (or some stock somewhere)? I have only just come across this issue and it is seriously going to affect the production of our medical device.
Peter BENSCH
May 11, 2021 9:39 AM UTC
The termination notification AMS/20/12518 contains 2021-06-23 as the date for the last order entry.
Maybe you still have the opportunity to place a last order at one of the distributors?
/Peter
ChrisSkelton
May 11, 2021 9:48 AM UTC
Hi Peter, thank you for your reply. Do you have a copy of the termination notice that you can send to me please?
The problem will be the lead time I suspect, I need the stock now, not in 3 months time or whtever the lead time will be. I have been chasing RS Compoennts for a week now but they cant tell me when they expect deliveries of thier orders. Would you know the answer to that? Cheers.
Peter BENSCH
May 11, 2021 11:11 AM UTC
You will find the termination notice if you enter AMS/20/12518 into you preferred internet search engine.
Delivery problems and stock issues should be clarified with the respective distributor.
/Peter
jeffl.kelley9
May 31, 2021 11:11 PM UTC
It is probably reasonable to discontinue the STMPE811 touch screen controller. However, an I2C port expander with the ability to have up to 8 analog inputs might be another matter. Perhaps explaining what the part can do in different terms would open new marketing possibilities.
User455
Apr 2, 2023 7:55 AM UTC
ST still sell products, which use STMPE811QTR anyway (e.g. STM32F429I-DISC1) and stop availability and producing of spare parts, and they do not offer any compatible device regarding this component?
Have I understood that correctly??
I​ would need this part, because it is defective (short circuit), and no dealer can supply it, what is the solution for this case?
Thank You!​
Peter BENSCH
Apr 27, 2023 4:24 PM UTC
see same question with almost the same answer here.
