ftemp
hi, i need help to identify a product probably discontinued, attacched the picture
BRYAN SPEED
September 5, 2019
It is a part for which information is not publicly available. Any replacement would have to be through the OEM of the product. I can say it is a N Ch Mosfet.
ftemp
ftempAuthor
hi, thanks for your really quick answere the problem is that it is an old object and the company that produced it is disappeared and it is almost impossble to get a replacement, if you can provide at list few little specific i can try to sobstitute it with a compatible device. thanks in advance for your answere
BRYAN SPEED
September 6, 2019
I wont be able to get access to the specs. However, if you can make some determinations of the operating paramaters, then a substitute can be found!
Basically, gate drive voltage used, VDD max, Drain current., that kind of thing.
