leoren_tm
Aug 17, 2010 2:07 AM UTC
Hi All, what compiler should i use?
Posted on August 17, 2010 at 04:07
#stm8-compilers #compiler #raisonance #cosmic #iar
lowpowermcu
May 17, 2011 1:10 PM UTC
Posted on May 17, 2011 at 15:10
Good luck :)
jeantil88
Oct 1, 2015 11:08 AM UTC
Posted on October 01, 2015 at 13:08
Hello Stefan,
I would like to try the Cosmic compiler with Eclipse. I have managed to built the project according the steps you wrote. But I am not able to flash the device with error:
C:\Cosmic\gmake.exe: Nothing to be done for `flash'.
Where exactly shall I write the lines ''flash : ...'' into the makefile?
Debug  is described quite briefly - would it be possible to write more detailed description of debug configuration?
I want to stop using STVD because of debug - it is enormously slow and whole IDE needs restart after several debuggings. Therefore possibility of debugging in Eclipse is very interesting for me.
Thank you a lot in advance.
Tony
Philipp Krause
Senior II
Oct 4, 2015 12:26 PM UTC
Posted on October 04, 2015 at 14:26
How about updating that comparison. It currently doesn't even mention the IMO best two compilers for the STM8.
Philipp
