DSaxe.1
December 10, 2019
hey everyone, how to read Hex file. any idea please ? I am using STM8500 5K6T6C
    December 10, 2019
    Read it how? Do what with it?
    It is a pretty simplistic ASCII file format from the late 1970's, can you use basic C FILEIO to read it?
    You want to download from an existing STM8500 to clone/copy it? Do you own the IP? Is it protected? Can you use an ST-LINK with ST-LINK Utilities or STM32 Cube Programmer to pull the content? Do they indicate they can't connect?
    turboscrew
    Senior III
    December 11, 2019
    Cristian Gyorgy
    After all, all files are HEX format - you cannot store anywhere a binary value alone.
    All togheter, 3 people wrote 7 lines to answer your question, but you could not take the time to put some sense into it, to try to explain what you want - you did it in 1 line.
    So, good luck with your hex file!
