leven333
Mar 2, 2012 1:02 AM UTC
help with st10 flasherV24b,can not reload monitor
Posted on March 02, 2012 at 02:02
Hi, I try to use st10flasher tool(Flasher_V24b). In windows xp works but when I try to read the mcu (st10f269) with dump I can save the dump only in text format. If I try to save in hex, the program report target not found. Before that,I try to ''reload monitor'', it show me ''Initmoitor failed.Monitor:loadMotitor:Bad aknowledge value 0xA5 instead of 0x5A''.could you give me some advices. I am sorry of my poor english.
bruno ,I also see you in keil forum,can you help me?
Liuqi
davetelling9
Oct 23, 2012 5:13 PM UTC
Posted on October 23, 2012 at 19:13
I am having the same problem with a ST10F276Z5 part. So far, I have not been able to find anything that helps with this. I have recently submitted a request to ST support, and hopefully, they will provide a working solution.
