jemondsalt9
Sep 4, 2009 7:41 AM UTC
Help to choice a compiler
Posted on September 04, 2009 at 09:41
jemondsalt9
May 17, 2011 7:59 AM UTC
Posted on May 17, 2011 at 09:59
I would like to know which is the preferred compiler (IAR, Keil, Raisonnance, …) for STR9 products? The best choice for me is the compiler which is used by ST and most part of developers…
Thanks,
Julien.
jomedfree
Julien,
If you want to try a gnu gcc solution, and expect to use ST products only, I deeply suggest Idealist IDE/Compiler from Anglia. It's free and...it works just ''out of the box''. I tried several gnu-gcc tools, only this one works when you have to work with floating point and printf (the other may work but not for a dummy like me!).
For the debug, I use a JtagKey, Eclipse, GDB and OpenOCD, but it is not painless to set up...
Good luck,
Joel
