huashilong
Sep 14, 2006 10:26 PM UTC
Posted on September 15, 2006 at 00:26
Dear Hich
I'm in hurry to implement RF unit with FM0/NRZI encoding, so l'm anxious to know the HDLC limitations. Can you give me some information about the HDLC limitations? thank you very much,
Regards,
lisihua2000@tom.com
hichem2
Sep 18, 2006 10:03 AM UTC
Posted on September 18, 2006 at 12:03
Could you please tell me what kind of limitations can cause you o lot of worry.
With regards,
Hich
huashilong
Sep 18, 2006 10:58 PM UTC
Posted on September 19, 2006 at 00:58
I know that REN and TEN bits are swapped on readback. I have got over the limitation in my program. My program can work well with NRZ/NRZI encoding now, but it can't work with FM0/MANCH encoding. I'm not sure the mistake is took by me or str71x. Could you please help me? thank you very much!
here is the code :
#define CODE_NRZ 0
#define CODE_NRZI 1
#define CODE_FM0 2
#define CODE_MANCH 3
void HDLC_Init(unsigned char tx_code,unsigned int tx_bps,unsigned char rx_code,unsigned int rx_bps)
HDLC->GA1 = 0;
HDLC->GA0 = 0;
HDLC->GAM1 = 0;
HDLC->GAM0 = 0;
HDLC->PRES = 0;
HDLC->POSS = 0;
HDLC->TCTL = 0;
HDLC->RCTL = 0;
HDLC->BRR = 0;
HDLC->PRSR = 0;
HDLC->TFBCR = 0;
HDLC->RFBCR = 0;
HDLC->PCR = 0;
HDLC->ISR = 0;
HDLC->IMR = 0;
HDLC->PARH = 0;
HDLC->PAMH = 0;
HDLC->PARL = 0x00AA;
HDLC->PAML = 0x00FF;
GPIO_Config (GPIO1, 0x2000, GPIO_IN_TRI_CMOS);
GPIO_Config (GPIO1, 0x4000, GPIO_IN_TRI_CMOS);
GPIO_Config (GPIO1, 0x8000, GPIO_AF_PP);
if((tx_code==CODE_NRZ)||(tx_code==CODE_NRZI))
HDLC->TCTL = (((unsigned short)1)<
HDLC->BRR = ((RCCU_FrequencyValue(RCCU_FCLK)/tx_bps-1) & 0x0FFF);
else //((tx_code==CODE_FM0)||(tx_code==CODE_MANCH)
HDLC->BRR = ((RCCU_FrequencyValue(RCCU_FCLK)/tx_bps/2-1) & 0x0FFF);
if((rx_code==CODE_NRZ)||(rx_code==CODE_NRZI))
HDLC->RCTL = (((unsigned short)1)<
HDLC->PRSR = ((RCCU_FrequencyValue(RCCU_FCLK)/rx_bps-1) & 0x00FF);
else //((tx_code==CODE_FM0)||(tx_code==CODE_MANCH))
HDLC->PRSR = ((RCCU_FrequencyValue(RCCU_FCLK)/rx_bps/2-1) & 0x00FF);
yahoo1
Sep 21, 2006 3:08 PM UTC
Posted on September 21, 2006 at 17:08
I received an offical answer for ST to the same question. I have attached this draft document. I'm worry to use the HDLC unit for my application whitch is possible similar to your. But in any case I will use STR7.
Kind Regards
Ioannis
huashilong
Sep 22, 2006 4:30 AM UTC
Posted on September 22, 2006 at 06:30
Dear elcom,
Thank you very much for your reply, I can't find the document you attached. Could you please attach it again or email to me?
thank you very much
Kind Regards
huashilong
yahoo1
Sep 24, 2006 12:17 PM UTC
Posted on September 24, 2006 at 14:17
Sorry, hope it is working now.
Kind Regards
Ioannis
________________
Attachments :
STR71x-HDLC-Errata.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtFM&d=%2Fa%2F0X0000000aKi%2FFBZz7EOJOgMxEAPJBf02nDiWAl_RIzqLZFV85D8x4I8&asPdf=false
huashilong
Sep 24, 2006 11:46 PM UTC
Posted on September 25, 2006 at 01:46
Dear elcom,
My application is for DSRC, I have to change my design now. You save my time equal to save my life. Thank you very much.
Kind Regards
huashilong
