pchignon
Aug 9, 2005 12:43 PM UTC
Hardware spec of the eval board
Posted on August 09, 2005 at 14:43
pchignon
pchignonAuthor
Aug 4, 2005 9:01 AM UTC
Posted on August 04, 2005 at 11:01
I am totaly disappointed. I have burnt the evalboard by a 12Volt power supply
But, I am sure I am not the only one :).
So I should change some components. I want to know which one? I have problem to find L9669 and L9616. Where can I find it or is there an equivalent component?
Thanks,
Ludo
halim
Hi Ludo,
You must change these components:
-1- IC7: ST662A
-2- IC5: L9669
-3- IC4: L9616
-4- IC19: 74LCX14
-5- LCD1-1: LCD2*16
Concerning problem to find L9669 and L9616 I suggest to contact ST- distributor
I hope that STR710 work again :)
With best regards,
Punto
