rajugnv
Feb 21, 2008 2:07 AM UTC
H-JTAG Issue
Posted on February 21, 2008 at 03:07
H-JTAG Issue
tsyejay
May 17, 2011 7:49 AM UTC
Posted on May 17, 2011 at 09:49
hi, rajugnv
have you succeeded to program either of the flash of STR91x with h-jtag? how to? thank you!
best regards
tsyejay
rajugnv
rajugnvAuthor
The device has been detected using the configuration
TAP Num – 1 IReg Len – 5
TAP Num – 1 IReg Len – Auto
TAP Num – 1 IReg Len – 8
rajugnv
rajugnvAuthor
I am trying to connect STR912 based target(self made PCB) board with Parallel Port Based Jtag hardware.
This is first time I am working on STR9. I am unable to detect target device through H-JTAG.
I am facing following problems..
I have kept TAP configuration as suggested in H-JTAG User Manual Fig 3-12
TAP Num – 0 IReg Len – 5
TAP Num – 2 IReg Len – 8
Iam getting device id as 0x12CB3020
When the TAP configuration is not done I got 0x02471E40
Both are invalid device ids.
In site link
http://www.hjtag.com/pic/TAPConfig.jpg
a different TAP configuration is mentioned like this.
I have not yet tried out this TAP configuration.
Please let me know which is correct.
Is Target Reset is must as shown in Fig:3-11.
And also can I use nSRST instead of nTRST to reset target hardware for the figure shown in 3-11 of H-JTAG user manual as I do not have support for nTRST in my JTAG hardware.
By seeing the change of Device ID received when TAP configuration is changed can I ensure chip is working to some extent.
Please let me know how I could proceed further in these circumstances.
Thanks in advance for the support,
rajugnv
rajugnvAuthor
NO. I could not. We are Using Keil ULINK to do it.
