adellarovere
Sep 15, 2009 6:45 AM UTC
gdb7 doesn t have MI Interface (doesn t work with Eclipse CDT)
Posted on September 15, 2009 at 08:45
#eclipse-debug-with
    adellarovere
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    Your gdb7.exe (revision 4.17) comes regrettably without Machine Interface support.
    Do you have a newer gdb (at least revision 5.1) for STM8 devices, in order that I can use it together with Eclipse CDT?
    Thank you in advance,
    Antonio.
    sramsauer9
    Hello Antonio,
    do you know how to implement Machine Interface support.
    The latest version of GDB Source (gdb 4.17, ST7 v3.9.16) can be downloaded from http://www.st.com/stonline/products/support/micro/files/gdb7.zip
    Stefan
    mnsacro
    Sep 14, 2011 1:57 PM UTC
    Posted on September 14, 2011 at 15:57
    Hello Antonio,
    I have tried to debug my STM8S source inside Eclipse IDE (Indigo) but I've encountered a problem.
    When I build and compile it (with Cosmic compiler launched by Eclipse), all is OK. But, when I try to debug (gdb7.exe), Eclipse say ''Program file does not exist...'' after compile and link actions.
    If I use STVD (ver 4.2.1 patch 2) in order to debug my code, all is OK.
    Do you have any suggestions about this problem ?
    Monte
    andrewgoedhart
    Oct 28, 2011 1:53 PM UTC
    Posted on October 28, 2011 at 15:53
    Do you still have the source available for the ST implementation of GDB. I am assuming it includes the ST-link protocol implementation.  In which case I may look at it and see how difficult it is to port to the newer interface. I am currently running under and visual develop which is why I am interested.
    the link given below no longer works.
    Andrew
