andreas_kristianstad
Dec 1, 2006 4:26 AM UTC
Posted on December 01, 2006 at 05:26
first of all I'm a newbie so be patient with me. My problem is the following:
I'm using a STR710-EVAL board and I'm trying to port the Freertos to it. I have loaded my program in ram 0x20000000 and I have remapped the memory to Ram. whenever I get a SWI the next I see in my GDB is that the pc = 0x08 and everything crashes. I recognize that this is the address of my Exception handler for SWI but the address should be 0x200000018 where the code is located??????
What is happenning.
peterwrigley9
Dec 1, 2006 9:37 AM UTC
Posted on December 01, 2006 at 10:37
Hi gea,
Program a simple jump table to RAM at address 0. Program this into Flash. When your interrupts fire, they will be redirected to your code in RAM.
sjo
Dec 3, 2006 5:57 PM UTC
Posted on December 03, 2006 at 18:57
This is based on an older version (v3.20) - not got round to updating yet (busy with str9). But is quite simple todo.
It uses the Anglia IDEaliST toolchain (gcc based).
sjo
________________
Attachments :
FreeRTOS.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtEn&d=%2Fa%2F0X0000000aKd%2FTsNxxtZj68SJcuO21yGHUWRdCNyLc_bdlJEEXtchroU&asPdf=false
