fabian239955_stm1
Jul 7, 2006 10:06 AM UTC
GCC example with STR710FZ2
Posted on July 07, 2006 at 12:06
fabian239955_stm1
Jul 6, 2006 12:41 PM UTC
Posted on July 06, 2006 at 14:41
hi everybody
I'm using the hitex str7 evaluation board with a STR710FZ2 cpu and for
programming and debugging I got keil ulink jtage interface.
For getting started I made some project with Keil uVision3 and the
Keil-CARM compiler, this was working pretty well. The project used the
STR71X library from ST.
Today I wanted to switch my project to the GNU GCC compiler. I spent
several hours for this procedure but I never reached my goal.
First I had to recompile the ST's STR71X library for use with the GCC
compiler, this worked and I got my ''libSTR71xLIB.a'' library file.
Afterwards I tried to include the library into my project but I didn't
succeed - there were always some linker errors, so I tried to setup a
simple project with (programmers notepad - no keil uVision - only some
files and a Makefile), but how could it be even this didn't work!
Now my question to you: Could anyone of you supply me some example files
for the STR710FZ2 and the GNU GCC compiler? I'd just need a example
project with Makefile. If I could get a Keil uVision project - prehaps
even with a precompiled STR71X library - I'd be more glad, but a simple
project with makefile wich I could compile using programmers notepad
(WinARM) would do it for the moment.
I only want to bring this thing to work with the GCC.
Thanks for your help in advance
Regards,
Fab
fabian239955_stm1
okay, now i managed to get it working even with my own compiled STR71X library.
maybe explanation will follow...
