Workalot
Apr 5, 2010 10:21 PM UTC
Function return issue
Posted on April 06, 2010 at 00:21
    Workalot
    WorkalotAuthor
    May 17, 2011 1:07 PM UTC
    Posted on May 17, 2011 at 15:07
    Ok - by having...
    int main( void )
      unsigned short usResult;
      usResult = Func();
      if ( 0 == usResult )
          usResult = 1;
      while( 1 );
      return0;
    ... does get a returned value in usResult since it is referenced after the call to func(). So, compilers are getting that clever - even on a debug build with no optimization.
    Always a new lesson to learn in this business - thank you for your response.
    luca239955_stm1_st
    you are putting the result of your function into a local variable that is never used -> it is probably optimized out.
    Try to use a global variable, it should work.
    Regards,
    Luca (Cosmic)
    luca239955_stm1_st
    Actually optimizations are done in different compiler passes: the parser, the code generator and the optimizer itself: when you ''turn off the optimizations'' you justr disable the last component.
