johnsim
Sep 19, 2005 7:53 AM UTC
From Debug to Release - problems with INTVEC.
Posted on September 19, 2005 at 09:53
johnsim
johnsimAuthor
Sep 16, 2005 12:03 PM UTC
Posted on September 16, 2005 at 14:03
changing from Debug to Release mode in IAR Embedded Workbench, using a the LED_DIMMER example as a starting point, I'm getting the following error when linking:
Error[e16]: Segment INTVEC (size: 0x428 align: 0x2) is too long for segment definition. At least 0x3e8 more bytes needed. The problem occurred while
processing the segment placement command ''-Z(CODE)INTVEC=00-3F'', where at the moment of placement the available memory ranges were
''CODE:0-3f''
Reserved ranges relevant to this placement:
0-3f INTVEC
Basic project is the same, but I've added in XTI and EIC files for my project. I've also commented out the in 71x_conf.h to change the library to release mode from debug.
Any suggestions what this is and how to fix it? I can only find one reference to INTVEC in Inkarm.xcl
Thanks,
John.
johnsim
johnsimAuthor
Thanks ibtiss, that did the trick!
John.
