FreeRTOS: LED not blinking with Blue Pill board
- 2 replies
- 372 views
Split from USART in Proteus not displaying any characters as this is now a new situation (real hardware; not simulation)
Now as per your advise i have moved from simulation to real hardware can you please why under freertos its not working the led is counitnusly onn instead of blinking?
Working behavior:
LED blinks correctly without FreeRTOS using a simple while loop in the same setup .
Flashing and debugging via ST-LINK works without issues.
Problem:
When FreeRTOS is enabled, the LED stays continuously ON instead of blinking under the same hood .
CubeMX configuration:
FreeRTOS enabled (CMSIS V2)
Default task created
USE_NEWLIB_REENTRANT enabled in FreeRTOS advanced settings
SYS timebase tested with:
SysTick
TIM1
GPIO PC13 configured as:
Output ( that is fine as it worked without freertos but stays counitnuoly on with freertos )
Code behavior:
Using osDelay() inside the task
Same toggle logic works outside FreeRTOS but not inside
What I have tried:
Switching between SysTick and TIM1 timebase
Re-generating code multiple times
Verifying task loop logic
Replacing HAL_Delay with osDelay
Question:
Why does the LED remain ON when FreeRTOS is enabled instead of blinking can you please check configurations for freertos ?
Is this related to timebase configuration, scheduler issue, or HAL vs RTOS conflict?
What am I missing in my configuration ?I m so confused here why it might beahvees like this i have attached the project folder can you please check this and inform where is an actual issue underlying?
Any help or suggestions would be appreciated. Thank you.
