FORTH for STM8S-Discovery
Posted on July 20, 2010 at 07:08
Here is a FORTH interpreter-compiler for Discovery Board. It is in the form of an assembly file stm8ef.asm. You can assemble it on STVD and download it to Discovery. You need a UART connection to Hyperterminal on PC to interact with STM8S microcontroller.
If you are lucky enough, or persist enough to get it going, the whole Hyperterminal project will be reduced to 6 lines of FORTH code:1 500F C! ; turn off LED
0 500F C! ; turn on LED
3E 50F3 C! ; turn on 1 KHz beep
7E 50F3 C! ; turn on 2 KHz beep
FE 50F3 C! ; turn on 4 KHz beep
1E 50F3 C! ; turn off beep
This is how microcontrollers are to be used. Good luck, Ting.
