joseph2399
May 17, 2011 9:59 AM UTC
Posted on May 17, 2011 at 11:59
Hi Nicky,
I am in marketing (a few of us logon as ''moderator'' to support the forum). You are correct; they will both program the part. The major difference is that the USB (called U-Link) was developed with Keil and supports the Keil IDE so that in addition to programming thru the JTAG port you can now perform JTAG debugging and monitoring. The µPSD3200 family only supports JTAG programming so the FlashLINK Parallel programmers does only programming.
In future versions of the kit we will even supply a ''programmer'' that support JTAG debugging with other vendor software in addition to Keil.
Hope that helps!
[ This message was edited by: uPSD on 02-03-2004 17:24 ]
vincent239955_stm1
Can anyone enlighten me whether is there any difference between the FlashLINK programmer found in DK3200 and DK3300, other than the USB/Parallel differences?
Technically, the programmer found in either kits can programme uPSD series right?
Thanks in advance!
