a_mali
Mar 2, 2006 4:22 AM UTC
flashing problem with St72f561 with indart-stx
Posted on March 02, 2006 at 05:22
a_mali
a_maliAuthor
Feb 22, 2006 11:34 AM UTC
Posted on February 22, 2006 at 12:34
We were flashing St72f561 using indart-stx with s/w DataBlaze Programmer Successfully, on two boards. For around 10 days there were no problem. Suddenly we were unable to flash both the boards. The flasher software started showing error, ''Communication error between Instrument & target device''.
Tried every possibility given in the DataBlaze Programmer's help, but nothing is working out.
Amit
nciot
Feb 24, 2006 5:41 AM UTC
Posted on February 24, 2006 at 06:41
Hi Amit,
maybe your inDART-STX is simply damaged. Did you try to contact SofTec Microsystems Support (support@softecmicro.com)?
Nicola
sergey3
Mar 2, 2006 2:40 AM UTC
Posted on March 02, 2006 at 03:40
You can work yet with debagger ? I had the same problem. Check
JTEG on your boards. :o
(I am working with ST72F561 + Indart-STX +DataBlazeProgrammer)
[ This message was edited by: sergeyna on 02-03-2006 08:13 ]
kalun218
Have you ever tried th diagnostic test? Is there any error message occurred?
Make sure that you have disconnected the target board from the inDART-STX programmer during the diagnostic test.
Also, in most of the cases, the communication error between the instrument and the target device is caused by the inappropriate configuration of option bytes.
The simply way is to contact support team of SofTec.
I hope the above suggestion can help.... :p
