wizard999
Jul 24, 2006 5:46 PM UTC
Flash programming/erasing times
Posted on July 24, 2006 at 19:46
wizard999
wizard999Author
Jul 24, 2006 2:29 PM UTC
Posted on July 24, 2006 at 16:29
I was searching for worst-case times when doing a sector erase and word programming, but I couldn't find it in the flash reference manual or the device data sheets etc. I am working on a bootloader for the STR712FR2 and the time the device is ''vulnerable'' against power loss when re-programming sector 0 is crucial.
Many thanks,
Chris
mohamed23
Jul 24, 2006 3:05 PM UTC
Posted on July 24, 2006 at 17:05
hello Chris,
You can refer to STR71x Datasheet on the following link
http://www.st.com/stonline/books/pdf/docs/10350.pdf
Then Section 2.3.3 : Memory characteristics
With regards,
Rave
wizard999
wizard999Author
Thanks a lot! :D
