Filters for HDMI
Hello Everyone,
We are interfacing HDMI Connectors with a microprocessor such as AM625 or AM62P or RK3568 for use in Industrial HMI Controller environment.
We would be using HDMI 2.0 or 2.1 data transfer rates.
We plan to use a HDMI companion chip such as the HDMI2C4-5F2.
We would like to use some filters between the ESD diode and the microprocessor for better immunity from noisy industrial environment.
Circuit would typically be Connect ----> ESD Diodes ----> Filters ----> Microprocessor HDMI pins. ( ESD Diodes and Filters shall be typically placed close to the connectors ).
For the TDMS pairs, we would use a common mode filter such as ECM4-2450A17M10.
However, we wish to know, what kind of filters are required for SCL, SDA, HPD, Enable and VCC pins.
Can you please recommend us some part numbers.
Regards,
Gaurav Joshi
FGUIT
FGUITBest answer
For TMDS/FRL lines, I recommend to use ECMF4-40A100N10, or ECMF4-2450A60N10.
ECMF4-2450A17M10 is on NRND status.
Solutions to protect and filter HDMI connector signal are presented on AN5121.
Regards.
Fabrice.
FGUIT
FGUITBest answer
Regards.
Fabrice.
Hello Fabrice,
Thanks for the response and sharing the application note.
Regards,
Gaurav
