de Vaal.Ruud
Sep 3, 2019 10:17 AM UTC
Failed to launch child process
Use ST visual development and all of a sudden I get this message:
Failed to launch child process <gdb.exe>
>error=2 - "The system cannot find the file specified.
    Ozone
    Principal
    Sep 3, 2019 10:26 AM UTC
    Don't know your IDE.
    But general experience tells me that many applications cannot deal with several instances at the same time, and refuse to start under that circumstances.
    I would check if some comatose instance of gdb.exe is still running.
    And, of course, that the executable is still there.
    de Vaal.Ruud
    Oct 14, 2019 1:10 PM UTC
    For some reason all of a sudden it worked for some weeks and now I get the same error again out of the blue. Reboot of the PC with ST visual only did not solve the issue.
    uhaid.1
    Jan 4, 2023 7:17 AM UTC
    I had the same issue. uninstall and reinstall method did not work.
    Update your windows, it works.
    YIshi.1
    Jul 20, 2023 1:00 AM UTC
    A few days ago, I made a mistake and left the weight on the return key, and a lot of STM32CubeIDE started up. I forcibly rebooted the PC in the middle, but after that I couldn't access ST-Link at all, so I had no choice but to process it on another PC.
    Today, when I tried to debug with STVD (for STM8), I got the same message as the questioner. I thought that the ST-Link driver might be broken, so I reinstalled it, and it returned as if nothing had happened. Is it possible that the driver is corrupted?
