emoktad
Mar 30, 2007 4:19 AM UTC
Failed flashing STR912 with caps
Posted on March 30, 2007 at 06:19
emoktad
emoktadAuthor
May 17, 2011 7:40 AM UTC
Posted on May 17, 2011 at 09:40
when I try to flash the STR9 with CAPS 2.40 I get an error message when programing configuration, I also have difficulties downloading firmware with IAR 4.40A. I am using the STR912FAZ44H6 (BGA), before I was using the STR912FW44X6 (LQFP) and i had not such problems. can some body help me? thanks.
M.A
emoktad
emoktadAuthor
I will give more informations so you can help me , the STR9 I am using is the STR912FZ44H6 (BGA) but this reference doesn't exist neither in CAPS 2.40 and the JTAG Programmer 1.20, so I choose the STR912FAZ44H6, sometimes it works but the most often it doesn't. Thanks
