cdixon
Mar 10, 2008 12:19 AM UTC
EXTINT5 -32 Interrupts
Posted on March 10, 2008 at 01:19
hicham
May 17, 2011 7:48 AM UTC
Posted on May 17, 2011 at 09:48
Hi cdixon,
Try the following post if you still haven't been able to solve your problem.
http://www.st.com/mcu/forums-cat-6516-21.html
Beware that you can only use one of the two buttons SCU WKUPSEL register does not allow you to select more than one. For documentation, check out
http://www.st.com/mcu/devicedocs-STR912FW44-101.html
. The first three pdfs are your most valuable information source.
However, I am also facing some side effects problems, but you can get a starting idea of how to make use of your push buttons.
cdixon
cdixonAuthor
Just a beginner so sorry if this is very basic question (I can't seem to find the required docs anywhere ;
How do I enable EXTINT 5 using ST Libraries ? (Using the MCB-STR9 Eval Board and I would like to use the Push Buttons, s3 and s2 (EXINT5 and EXINT6)
