wbu
Jul 16, 2003 5:27 AM UTC
External Flash memory adressing
Posted on July 16, 2003 at 07:27
yu-jun
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
You can use Ports A and B to generate A12-A21.
If you have any question of the uPSD, you can write some easy code to use demoboard
wbu
wbuAuthor
I don't want to use the internal Flash memory but need to address an external Flash memory of 2MB. For this I need 21 address lines.
AD0-7 and A8-11 are available.
Am I correct that it is possible to use Ports A and B to generate A12-A21?
Maybe it's a silly question but I don't have any experience with the µPSD so far.
Thanks in advance for any comments.
Regards,
Werner
chris_baragnon
hello!
you have to define extra adress line on PLD port (A,B) like in the AN 1560 (a15_x, a14_x,...) and access to a memory on 22 bits.
hope this help.
totof
