jm_it
Jun 30, 2005 3:44 AM UTC
external bus on st10f168
Posted on June 30, 2005 at 05:44
jm_it
jm_itAuthor
Jun 29, 2005 10:33 AM UTC
Posted on June 29, 2005 at 12:33
I work on ST10F168 with 2 * 1Mb * 8 bits SRAM on external bus. I use A1 to A20 and WRL for the first ram and WRH (P3.12/BHE) for the second. It works very good.
But i would to know if i can use only one write signal for the 2 ram. For example the WR signal on the 2 chip.
Because i want to connect a 16 bits sram with just one WR.
Thanks in advance
jm_it
jm_itAuthor
Jun 29, 2005 12:16 PM UTC
Posted on June 29, 2005 at 14:16
Thank you for your answer and your precision !
But i don't understand why we can't use external bus with just 1 CS, 1 RD, and 1 WR when it works in 16 bits non-multiplexed ???
Best regards
