dolgov
Mar 2, 2009 6:14 AM UTC
Ethernet with uIP-stack
Posted on March 02, 2009 at 07:14
dolgov
dolgovAuthor
May 17, 2011 7:57 AM UTC
Posted on May 17, 2011 at 09:57
Sorry for disturbing.
I finally managed to run the example
dolgov
dolgovAuthor
I'm trying to get to run ST's ethernet example which uses the uIP-Stack. The only things I changed were the MAC and the IP addresses. I'm using the MCBSTR9-Board from Keil.
Pinging the board works perfectly but when I try to access the index.html the processor calls DAbt-Handler with infinite loop (in other words it freezes).
I traced the problem back to the uip_chksum function: the DAbt-Handler is called when the function tries to access the data to calculate the checksum.
Does anybody have a clue or has a working example??
Thank you for help
