Ethernet tool to analysis
Hi
I am trying to communicate via ethernet on STm32f407 board with phy LAN8720. I have used TCP protocol and I have used Hercules for sending and reciving frame. But I want to acheive the operation sung HAL_ETH_Transmit (I want to send raw ethernet frame ).
note: Can you suggest me any tool I can use to analysis Ethernet frame (send and recv.) tool like USB CAN analyzer for CAN .
 B.R
Ash
Andrew Neil
Andrew NeilBest answer
Have you looked at LWIP_HOOK_UNKNOWN_ETH_PROTOCOL: at https://www.nongnu.org/lwip/2_1_x/group__lwip__opts__hooks.html#ga6cc92f5101dd7a0420e18e1f2101abf4
via: https://community.st.com/t5/stm32-mcus-embedded-software/example-using-hal-eth-without-lwip-for-raw-ethernet-frames/m-p/416846/highlight/true#M31457
You might get some ideas from the rest of that thread...
Also: https://community.st.com/t5/stm32-mcus-embedded-software/goose-message-sending-using-lwip/m-p/158029/highlight/true#M9287
Andrew Neil
As I said in your earlier thread, Wireshark is the de facto standard ...
https://www.wireshark.org/
Nothing specific to STM32.
Ash1Author
hi Andrew
Can you tell me how I can send a frame via wireshark to my board.
Note1: I have achieved sending and reception via hercules, But now I want to achieve with raw frame using HAL library directly instead of TCP/UDP protocols and I can see frame on tool and can send frame from tool this was my query (I have tried Wireshark but I am unable to understand how I can send frame to my board ) I hope you got my point?
Note2: Is it possible whatever I asked you above or using TCP/UDP any protocol is mandatory?
B.R
Ash
mƎALLEm
To my knowledge Wireshark is not intended to send ETH frames but to sniff and scan the network.
You can use Hercule to send and receive TCP or UDP packets.
mƎALLEm
There is also https://packetsender.com/  or Release EchoTool · PavelBansky/EchoTool (github.com). tools motioned in this article: How to create a IPv4 NetXDuo Ethernet UDP application for STM32H5 with TrustZone® enabled
See the section 12. Testing the application in the article.
Andrew Neil
