cstoidner9
Apr 8, 2007 6:18 AM UTC
ethernet-dma
Posted on April 08, 2007 at 08:18
ethernet-dma
cstoidner9
May 17, 2011 7:40 AM UTC
Posted on May 17, 2011 at 09:40
I am using only one Rx DMA descriptor.
best regards
Christoph
anis
Are you using only one Rx DMA descriptor or a set of descriptors?
Best regards,
STARM
cstoidner9
I want to use continous Ethernet-DMA transfer with a ring buffer. But when I set the continous flag (CONT_EN, bit 12) in the RX Control Register (ENET_RXCR, offset 14h) the transfer stops after one received frame. Is there anything more to do to enable the ethernet-dma to copy all received frames consecutively in the ram ?
