Error when trying to compile using Arduino IDE for Blue Pill
Hello!
I've been uploading code to my STM32 Bluepill using my computer but it died recently and I had to use a different computer. After adding the library for the STM32F1, i tried to compile and upload again but i received these errors. Im a bit lost on where to start and would appreciate if anyone could help point me in the right direction for a fix!!
The error code from the arduino terminal is as below
exec: "C:\\Users\\hisha\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools\\xpack-arm-none-eabi-gcc\\14.2.1-1.1/bin/arm-none-eabi-gcc": file does not exist
Compilation error: exec: "C:\\Users\\hisha\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools\\xpack-arm-none-eabi-gcc\\14.2.1-1.1/bin/arm-none-eabi-gcc": file does not exist
Andrew Neil
Andrew NeilBest answer
Note that Blue Pill is not an ST Product, and likely does not contain a genuine STM32.
This forum isn't focussed on Arduino - the place for STM32 Arduino support is: https://www.stm32duino.com/
For general Arduino Support:  https://forum.arduino.cc/
arm-none-eabi-gcc is the compiler executable - so your GCC compiler is not (properly) installed.
Arduino IDE specific forum: https://forum.arduino.cc/c/development-tools/ide-2-x/93
Andrew Neil
Ah gotcha apologies and thanks for the clarification
Ozone
Principal
October 15, 2025
Dabbling in Arduino occasionally, I think it means the corresponding platform ("boards" in Arduino jargon) is not installed on this PC. Check within Arduino's  "board manager".
PS:
And yes, Arduino is not well supported on this forum.
Although a few members have some experience with it.
Andrew Neil
@Potatogineer  in particular, STM32 (or, in fact, any Cortex-M MCU) needs a different compiler from AVR (the "traditional" Arduino MCU).
Ozone
Principal
October 15, 2025
The same toolchain should work for all boards based on Cortex M devices.
Not sure about the Arduino equivalent of the respective BSPs.
