michaelkalusche9
Jul 13, 2006 8:04 AM UTC
Error when building the uClinux kernel
Posted on July 13, 2006 at 10:04
michaelkalusche9
Jul 13, 2006 4:50 AM UTC
Posted on July 13, 2006 at 06:50
Hi!
I´m getting an error when building the kernel. I am trying the use uClinux according to the Getting Started application note.
It works until i get to the step: run the following command ''make lib_only''.
Leaving directory ´tmp/uclinux-dist/uClibc/libc/misc/assert´
***[_dir_assert] Error 2
From this point on several errors occur (all ''leaving directory'') and at last the zimage.bin is not built.
Does anyone know what I´m doing wrong?
For information: I´m trying to build the kernel in cygwin running on a WinXP machine.
Thanks, Michael
michaelkalusche9
OK, thanks. But is it possible to compile an application independently from the uClinux image under cygwin?
