Aparna
Error: Program "gcc" not found in PATH
    January 31, 2020
    Then add the directory the tools are installed in to the PATH environment variable.​
    Aparna
    AparnaAuthor
    Can you please, help me to sort out that issue because i am using first time this IDE i don't know any thing about that SPC5Studio.
    February 2, 2020
    Determine where the GNU/GCC tools are installed on your system.
    Determine if the path to these gets into the PATH environment variable,
    Determine if the tools/installer are compatible with the version of Windows being used.
    Determine if you have administrative rights to install the tools properly.
    Try to not install things in the "Program Files" sub-directories
    Check AV and DLL related issues
    Engage your IT staff
    Engage your local ST support engineers or FAE
